Chemstation macro question
Posted: Sat Aug 11, 2018 3:11 am
				I've just started writing chemstation macros. I have a macro that outputs some data in csv format to a file. If I load and run the macro from data analysis, it runs fine. If I specify the same macro as a post processing macro for my method, I get an error "undefined symbol" when I try to use the TIC command. Is there some other macro I must first load before attempting the TIC command?
