MW distribution test/calculations for Dextran 70 (USP)
Posted: Wed Jul 16, 2008 7:34 pm
Dear Chromatographers:
We have got a new project: to perform the MW distribution test for Dextran 70 per USP (using SEC).
Commercial off the shelf (COTS) software packages available can do the calculations if there are narrow standards with known MW; or if the viscosity info is available for standards (Mark-Houwink approx.).
However, COTS packages cannot do the calculations for the top 10% or bottom 10% of the MW distribution, as required by USP.
USP states that an appropriate method to calculate the constants b1 thru b5 is the Gauss-Newton (modified by Hartley), or Nilsson-Nilsson method. I have got the article by Nilssons, and found that the authors referred to the Hartley modification of the Gauss-Newton method.
There were no sample calculation data provided in the article, nor chromatogram, and the number of iterations done was not listed. Info on the Gauss-Newton can be found in Wikipedia:
http://en.wikipedia.org/wiki/Gauss-Newton
We have contacted tech dept. of USP, and asked referral for a contract lab capable of doing this test, but USP declined to provide referral.
Do you know a contract lab that can do this test? Or anyone can function as a consultant? Or can someone provide a reference to a better/latest reference/article?
I realize the potential problem when I did some background reading. The initial selected values in a Gauss-Newton method may lead to non-convergent series. Also, it may be impossible to achieve the "best-fit" curve (Gauss-Newton method was designed to achieve a "good-enough-fit").
This project is rather urgent for us, because we need to certify a supplier. Thanks all for your input.
Alfred.
Alfred.
