How to Adjust an adjustable valve restrictor
Posted: Wed Aug 08, 2018 6:49 am
I am using a pora plot u column and a molsieve to measure permanent gases and c1, c2 gases. I have to isolate the molsieve when co2 and c2 gases come out.
I am using a six port valve to isolate the molsieve column.
when isolating the molsieve the plot coloum is connected to the detector through a adjustable restrictor.
Can someone please tell me how to adjust this restrictor to apply same back pressure as the molsieve column
Thanks a lot
Thanks a lot
