Can someone define the "Donan effect"?
Posted: Tue Jul 15, 2008 11:03 pm
I was reading about the PolySULFOETHYL Asparatmide SCX column here and the author mentions the Donan Effect about midway down the page.
From the context, it sounds like it has to do with an overloading of the column, possibly due to having an injection solvent that's too strong for the chemistry of the column.
I tried to wiki/google for an answer, and all I could find is a considerable amount of articles that use the term without defining it. I'm hoping someone here could explain it. I've seen two different "overloading" effects before, one that's dependent on the concentration of analyte introduced to the column (which I see as a wide, right-rectangular peak shape) and one that's dependent on the strength/volume of the injection solvent (which I see as an amorphous "peak" that elutes just prior to the main peak). Is it either of these situations, or something completely different?
