Separation and quantification of two different HPMC Grades
Posted: Fri Aug 03, 2018 5:56 am
by DRVKS
Dear all
Could you please suggest a HPLC method for separation and quantification of two HPMC grades from a tablet matrix having molecular weight difference of around 1000000.
The problem is both are co-eluting at same RT.
Re: Separation and quantification of two different HPMC Grades
Posted: Fri Aug 03, 2018 12:21 pm
by HPLC chemist
As I recall HPMC is a polymer and will have the same peaks, thus the RT is the same. The grade of HPMC is dependant on the quantitation of the peaks or the main peak (like PCB's). Rather than HPLC, you may be better off measuring the viscosity over time (like corn starch).
Posted: Fri Aug 03, 2018 12:25 pm
by HPLC chemist
Posted: Mon Aug 06, 2018 11:37 am
by DRVKS
Hi Thanks for your response but in a compressed tablet how you can quantify by measuring viscosity as it also contain other excipients.
the concern is separation and quantification of two different grades of HPMC (having difference in molecular weight of around 1000000) from a Tablet.
I hope my concern is clear now.
Regards
Posted: Wed Aug 08, 2018 4:06 pm
by dap
Hello.
We use
https://www.phenomenex.com/Products/HPL ... Sep-SEC-S/ column for water soluble polymer (chondrotine sulfate).
Posted: Thu Aug 09, 2018 4:07 pm
by HPLC chemist
Your concern is unfathomable to me. HPMC is an excipient and not worthy of quantitation by HPLC or any other 'expensive' instrument. While HPMC will affect validation of a process so will other variables like compression time and pressure. Thus, HPLC will not help you determine the amount or grade of HPMC (if you are trying to re-generate a drug product).
You may have to take a lot and split it to perform a PPQ (process performance qualification). There are no shortcuts!
Posted: Tue Nov 13, 2018 10:40 am
by akshay9960948682
what method u had tried for detection of hpmc on hplc
Posted: Sat Dec 08, 2018 7:03 pm
by Geof235
Have you tried Size exclusion chromatography?
