HP1047A RID - connect to recorder or integrator A2D?
Posted: Sat Jul 28, 2018 4:13 pm
Hi everyone,
We're installing a HP1047A RID via a analog-to-digital (A2D) card on my back of my controller (Shimadzu LC-10 HPLC). Everything seems to be working fine, but I'm not sure if I should be connecting it to the 'RECORDER' or 'INTEGRATOR' leads on the back of the RID. I have a strong guess its recorder.
I tried connecting to both and we're getting a signal, I'm just not sure which is the correct one.
Essentially there are three connection options: connect it to RECORDER using 0 as ground and using either (1) 10mv, or (2) 1mv, or use simply use the (3) INTEGRATOR leads and use the + / - leads. See photo below.
https://1drv.ms/u/s!AjglVmUkgtjLonJQOU5KlBuvQRKI
Can anyone shed any insight on how to correctly connect this?
Thanks.
Thanks.
