Negative peaks using Normal phase
Posted: Fri Jul 11, 2008 3:31 pm
by liam1978
Hi, Im getting na lot of negative peaks on my chromatography using a normal phase where I used to get positive peaks!!! This has happened before occassionally but it usually sorts itself out - is this a common occurrence with normal phase lc and why does it happen?????
Posted: Fri Jul 11, 2008 4:55 pm
by zokitano
What kind of detection method are you using? What is the composition of your mobile phase? And what type of analytes you're analyzing?
