glycol analysis with DB-5
Posted: Fri Jul 27, 2018 12:55 pm
I need to analyze glycols with GC-FID, the compounds appear in EPA 8015 and it says that the extraction is by azeotropic distillation with direct injection of water samples. I have a DB-5, is this a column for this type of injection? i think not.
With this column, can i analyze glycols? If not, what other method or column do you recommend?
Thanks.
Thanks.
