NIST 2017 Update
Posted: Thu Jul 26, 2018 10:36 am
by IonTrapSI
Hi. I would like to ask if some of you have purchased the newest NIST 2017 library update?
This is the first update that has only one activation code, which means the update can be used only once, i.e. on one PC. Since we have 5 instruments, we would like to install the update on all of them,which is impossible because once you use the activation code on one PC, it can not be used second time.
Any recommendations and suggestions how to solve this issue using "alternative ways"?
Thank you in advance.
