Detect aflatoxins in urine
Posted: Sun Jun 29, 2008 2:17 pm
Hello Friends,
I am trying to detect aflatoxins in pig urine by use HPLC system but the recovery is low and variation so much. Here is the protocol: Pig urine is incubate with beta glucuronidase in sodium acetate 0.2 M pH 5.5 for 16h, after incubation add 10 ml of phosphate buffer ph 7 then it will be extract by extrelude column with 60 ml ethyl acetate: acetinitril (9:1) to round botton flask. Evaporate the extract to dryness in rotar evaporator, dissolve residue in 1 ml of ethyl acetate-acetonitril (9:1) and transfere to 10 ml vial. Rine flask with additional portions of ethyylacetate followed by methanol. Evaporate combined residue and rinses to dryness under nitrogen in heated dry block. Dissolve the urine sample extract in 1 ml methanol-water (8:2), dilute with 15 ml PBS and mix. Pass the sample solution through the Immunoaffinity column (Rhone Easi Extract Afla) and let it pass at a speed of 1 drop per 2 seconds by gravity. Wash the column with 15 ml of PBS and dry by passing air through the immunoaffinity column. Elute the aflatoxins in a three steps by apply 0.5ml acetonitrile on the column and let it pass through by gravity (1 drop/2-3 seconds). Collect most of the elution solvent by passing air through. Evaporate the extract under nitrogen to dryness and derivatizate with 100µl trifluoroacetic acid in 5 minuses and dissolve with 900 ml of acetonitril-water (1:9) and put in HPLC. The mobile phase was acetonitril:water (2:8). LC column: Novarpack C18 4µ, 150x4mm, Water. Guard-pak column Novapark C18 4µ, Waters.
Fluoresence detection with Exitation 365 nm and Emission 435 nm.
I was also silanized all round bottom flasks and vials by dichlorodimethylsilane in 20 minuses.
If you have any ideal, please let me know where can I improve my procedure.
Best regards
Ngueyn Quang Thieu
Best regards
Ngueyn Quang Thieu
