Questions on protein analysis
Posted: Thu Jun 26, 2008 2:55 pm
Note: these were originally 8 separate posts combined by the Admin.
a mobile phase containing salt/high salt.. how does it work in SEC?
hi all..
i have protein recovery problems in analytical size exclusion chromatography? what are the chanegs i can make to the existing method/ mobile phase? its an ammonium bicarbonate buffer, pH 7. and why? thanks.
or how do i have a more sensitive method in such a case?
hii.. can some1 explain to me the differences and reasons for use of the following in Size exclusion chromatogarphy?
Mobile phase:
1. Ammonium bicarbonate buffer, pH 7 at a flow rate of 0.5 ml/min, detection at 215 nm.
2. Phosphate buffer,Ph 7
3. Phosphate buffer with 110 mM sodium chloride, Ph 7
4. Phosphate buffer with 110 mM sodium chloride, Ph 7 with 10% ethanol
all 4 with Same column, at a flow rate of 0.5 ml/min, detection at 215 nm. for all.
and what is the best prefered diluent in all these cases?
please let me know why for all!
thanks!
hii..
how to increase recovery of low amount of protein impurities in reverse phase hplc methods?
hiya!
what is the kinda system suitabiliyt you guys have for quantitation methods using liquid chrom.. ?
hi all..
pls help me with this..
how do u determine accuracy for a test for impurity quantitation by Liquid Chrom.? give me an idea of the experimental design and data interpretation pls.. confusions!
hi all..
for a purity test using say, rp-hplc or sec.. generally LC.. is it recommended or needed to demonstrate linearity across the range?
i mean.. if my sample injection amount is 30 micrograms, call it 100%, do i need to demonstrate linearity for 120% amount to 2% or less.. i m claiming impurity detection up to 2%? if yes why?
secondly, if there is no linearity in the response what are the effects?
third, for eg..
if i get an underestimation / overestimation at the level of 5-1% impurity amounts.. and they fall in a linear range, while the 80-120% amounts fall in another linear range but all together do not.. does it affect anything?
in such a case how do you calculate accuracy for impurity detection?
pls let me know.. hyper-confusion and difference in opinion with others!
thanks!
hii all..
what do u guys do to define yr method varation?
say i have a purity test, where i quantitate my impurities.. by LC.
i get an accuracy of 70% ie. compared to my 100% standard injection, my impurities which is say 5% (ie a low amount) is detected with 30% inaccuracy.. of course there is a variation above this. when i reanalyse the sample.. my precision varies to detecting 20% variation ie. the 5% is estimated between 20%RSD of the 5% imppurity (4.something to 5.something types). what is my method variation here?
would it be 20%, 30% or 50%? and WHY?
suppose i have a low accuacry of say 50% at my 2% impurity levels, which has a variation - imprecision of 10% how do i do it there? what are the kind of limits you guys set?
suppose i need to define the signal and noise for DOE experiments for process characterization how do i do it?
thanks!
hi all..
Mobile phase:
thanks!
hii..
hiya!
hi all..
hi all..
third, for eg..
thanks!
hii all..
thanks!
