I´ve been looking through this forum and many more, including tutorials and manuals but could not find an answer. I would be grateful if anyone could help me a bit.
Basically, I just want to set up an SST in Chromeleon 7. Let's say that I want Chromeleon to use a peak.area of the first injection as a Ref.Value 1 for the following samples used for SST. I want to be sure that the response does not lower during the measurement. (Of course, It can be done later in the results, however, I would like to utilize the feature of stopping after failed SST).
I think it would be easy if I knew the right commands, however, I was able to find only a list of Excel-like formulas. I am looking for something like this
peak.area(inj.1,"peak2") or Inj(1).results(peak.area)
of course, this is totally wrong however, I hope you get the idea. Did anybody else try that before? Or do you know about any list of the commands?
I would really appreciate it.
Thank you
