Connections in 2-switches 10-port valve for 2-dim. HPLC
Posted: Tue Jun 24, 2008 4:38 pm
Dear LC-Forum experts,
I need use 2-dimentional chromatography to be eliminate interference
from some blood-serum samples of end-stage renal disease patients.
First column is silica HILIC/Trifluoroacetic acid/MeCN/H2O and the other
is ReversedPhaseModePrimesep200/Trifluoroacetic acid/MeCN/H2O.
Sample, after deproteinization with HCLO4 and diluted with MeCN, is well
separated on the HILIC column with peak retention time of 7.1 min.
Interference size is ~ 0-10% of usual peak size, and not visible.
Instrument is Ultimate 3000 microHPLC with dual 3-gradient pumps and
autosampler. Theare are both 2-swithable 10-port Rheodyne valves
controlled by Chromeleon. Left is not in usage. Right valve is connected
to autosampler and 2 columns, by serviceman as 1-2 and 10-1 modes.
This may not to be change.
I have some examples of computer Programs on Chromeleon.
My problem is about how to made connections to columns and outputs
to be make 2-dimentional chromatography using above free left valve?
sincerely
sincerely
