Sporadic noise?
Posted: Tue Jun 24, 2008 8:59 am
by Daryono Hadi Tjahjono
Dear Colleagues,
We have small problem in suitability test of HPLC method for analysis of pseudoephedrine (P) in human plasma using phenylpropanolamine (PPA) as internal standard. Chromatogram show noises which appear unconsistently/sporadically between PPA and P. Although it does not affect the resolution and linierity, it disturb our clean chromatogram of plasma blank. We use Waters Alliance 2695 with UV Vis detector. We make sample pretreatment by liquid-liquid extraction. Do you have any suggestions or comments? Thank you for your suggestions and comments. Best regards, DHT.
Posted: Tue Jun 24, 2008 6:18 pm
by tom jupille
Isocratic or gradient separation?
From your description, it sounds as though the noise sometimes shows up in blanks. Is that correct?
Posted: Wed Jun 25, 2008 10:30 am
We use isocratic elution. These peaks did not appear in blank with the same threshold.
