No sample signal with HP1050
Posted: Mon Jun 16, 2008 11:12 pm
I recently got a HP1050 (79853A) which came up with 'Filter error, Low illumination, Data underflow'. (in that oder).
After tinkering (improved aligning) with the lamp I could fix these errors but the lamp shows signs of degradation (traces of metal on the bulb).
My only remaining problem is that I can't take measurements (which is bad...).
The problem is that the reference photocurrent is about 1.6 at 230 nm whereas the sample photocurrent is a steady zero at that wavelength with mounted flowcell. The noise is around 0,03 AU.
At around 350nm I get a reference photocurrent of about 0,23 with 0,029 for source and mounted flowcell. No noise is observed here.
Without the flowcell the sample current is around 0,9 for all wavelengths.
I flushed the flowcell with EtOH:H20 1:1 and later 100% MEK which didn't change anything.
Therefore I have several questions:
- Are these symptoms are sign of a worn lamp? (esp. the low S. current)?
- Does anybody here have a service manual for the 79853A with an 'early' optics compartment (seems like Rev. B)?
- What kind of material is applied to the mirrors of the detector? As I have access to a high vacuum sputtering apparatus I could regenerate these mirrors if only I knew what is applied (in what order) to them
Thanks for helping me out!
