Negative peak response
Posted: Fri Jun 13, 2008 8:50 pm
Virtual colleagues,
I have encountered one of those "beat-your-head-against-a-wall" problems.
About 3 weeks ago I successfully obtained UV/TIC data for a Decitabine, 5-aza-2'-deoxycytidine, intermediate. The separation is accomplished using a Synergi Hydro-RP 250 x 4.6 column w/ water/THF (90/10 v/v) as MP A and ACN/THF (90/10, v/v) as MP B on an Agilent 1200 LC coupled to an Agilent MSD SL G1956B run ES positve mode.
Of course, now I can't reproduce the analysis. I was having a relatively high background, ~ >500,000 response units, the second time around. I contacted Agilent and was directed to flush the system w/ a cleaning "cocktail". This appears to have been succesful as various configurations of the system - w/, w/o column, direct to nebulizer from pump, different channels, etc., provides very similar background traces ~ 50,000 response unit. However, when I injection the sample solution (in ACN) I obtain good UV trace, but I also obtain negative peak responses in the TIC.
I have no idea what's going on and would appreciate comments/suggestions.
