Aanlysis of peracetic acid by Gas chromatography
Posted: Sat Jun 07, 2008 8:37 am
by praveenpaliwal
Hellow,
I am praveen I want to know that can we analyse the peracetic acid on GC chromatography. If yes than waht is the condition.
Praveen
Sr. Chemist
Posted: Sat Jun 07, 2008 10:51 am
by chromatographer1
I have never heard of this chemical having a stability adequate to perform an analysis reliably.
It may be possible, but I doubt it.
One may decompose it to acetic acid and determine that content.
There are other tests to determine purity other than GC.
Good luck,
Posted: Fri Jun 13, 2008 3:58 pm
by praveenpaliwal
Dear Rod ,
I want to kow what are the other tests for per acetic acid
Regards
praveen
Posted: Sat Jul 12, 2008 4:21 am
by beardguy
The best way is by titration iodometrically. If there is hydrogen peroxide, however, you'll need to titrate that first with cerium. Do a google search for peracetic acid and ceric sulfate - it will be one of the top hits.
Alternatively, a quick and easy method for PAA in acetic acid, is C13 NMR:
% = PAA/(PAA + Acetic acid)
Cheers,
B
