GC head column pressure and calibration linearity
Posted: Fri Jun 06, 2008 2:50 pm
Did you have yet experienced a loss of linearity response (tri or tetrachloroethylene, CHCL3, CCL4 and other chlorinated volatiles compounds, Internal standard calibration) with an high head column pressure ?
Is this possible ?
We operate with automated SPME in Headspace mode (20 ml vials filled with 15 ml sample/water and 3.5g of NaCL) and we inject @ 25psi head pressure with a 0.32mm column. Same results with different fibers (CAR/PDMS, DVB/CAR/PDMS, PDMS or DVB/PDMS). We have a liner of 0.75mm diameter and a Merlin septum.
We operate with an on-column injection.
All opinions are appreciated !!
Thank you a lot,
Joe
Is this possible ?
Thank you a lot,
Joe
