Amino Acid Analysis
Posted: Wed Oct 06, 2004 4:56 pm
I'm having trouble putting together an amino acid method using a UV detector. I'm trying to analyze raw amino acid material, specifically L-Arginine, L-Glutamine, Glycine and Lysine. I purchased PITC to try and derivate the amino acids so they can be detected in the UV range, however I'm not getting any results. Here is the sample prep and method I'm running.
Sample Prep: dissolve 5g of amino acid in 1L of H2O, dilute 10x500mL for a 0.10mg/mL concentration. Transfer 4mL of 0.10mg/mL Amino Acid sample into test tube and add 1mL EtOH:H20:TEA (2:2:1). Mix well. Add 500uL EtOH:H20:TEA:PITC(7:1:1:1) and incubate at room temperature for 30mn. Add 2mL Hexane to test tube, mix and extract Hexane layer into seperate test tube (perform in triplicate). Evaporate Hexane layer using air hose (it's all I have in the lab-no vacume set up). Reconstitute sample using 4mL H2O and filter into autosampler vial.
HPLC Specs:
mobile phase: A= 90/10 0.5% KH2PO4/ACN B= 60/40 ACN/H2O
Run on Gradient 20-100%B Convex in 60mn.
Column: 4um phenomenex synergi hydro pro RP C18
I'll try to paste a chromatogram of my results but I'm not sure how. Please help if you can, thank you.
HPLC Specs:
