Empower custom calculated field
Posted: Fri May 30, 2008 4:17 pm
by TTran
New to the forum, I need help on creating a custom calculated field in empower. Any help will be appreciated
I like to create a custom field in empower that will calculate the % Difference (%D) in the average response factor (RF) of a reference peak for two standards following this equation
%D = [Average RF (Std1) - Average RF (Std2)] / Average RF (Std1) x 100
The sample set is as followed
3 injections of Std1 followed by 2 injections of std2.
TTran
Posted: Thu Jun 05, 2008 8:07 am
by aceto_81
Maybe you should give us some more information about what kind of software you are using?
Ace
Posted: Thu Jun 05, 2008 6:43 pm
by TTran
I am using Waters Empower v. 1 build 1534
TTran
Posted: Thu Jun 05, 2008 7:14 pm
by bartjoosen
Ace
:oops: Posted in the wrong thread...
Maybe I'm wrong, but this sounds like intersample calculations, and I'm not sure that this was possible with Empower 1.
If so, take a look at the help pages for intersample calculations, you should label your references and use this labels to get the custom fields to work.
GL
Ace
Posted: Thu Jun 05, 2008 8:38 pm
by TTran
Thank you for replying.
My sample set is as follow:
Code: Select all
Sample Name         Injection   Label
Std1                 1             A
Std1                 2             A
Std1                 3             A
Std2                 1             B
Std2                 2             B
I created result custom fields with the following equations.
ARF_A = A..(AVE(RF))
ARF_B = B..(AVE(RF))
use the above equation, instead of calculating the Average RF, Empowers listed all 3 RF values for RF label A and 2 RF values for RF label B
Did I do something wrong?
I figured it out
Posted: Sat Jun 07, 2008 5:01 am
by TTran
Thank you all, I figured it out. Forgot to add a summary calculation in sample set
