OpenLAB CDS Chemstation Calibration Table Issue
Posted: Tue May 01, 2018 3:29 pm
After running a sequence with set calibration levels the resulting automatically-generated calibration table is populated with incorrect peak area values. The update response factor/retention time columns are set to "replace" so it's not averaging anything with past data. If we delete the calibration table and recreate it manually, it populates with correct peak areas. Is there a setting being missed here?
Also, as an aside, is there an intelligent reporter expression that references the dilution factor for a given injection?
