Sulphur coumpounds using GC with a PID
Posted: Thu May 29, 2008 9:31 am
I'm supposed to setup a method for the determination of sulphur compounds from different rotten foods. The sulphur compounds are produced by microbial fermentation and we have no idea of their concentration.
I'm using an old HP5890 series II GC, with a HNU PI 52-02A Photo Ionizing detector (PID) and a FID. My sampler is a Tekmar 7000 Automatic headspace sampler. Although the machines are old, and little or no support at all is available, they work and have performed for me in multiple other analyses before. Except the PID, I just installed it and I haven't got much experience of using it.
I've been trying to setup the method using a Restek 59% Carbowax 80/120 Carboblack-B 2mx2mm packed column, with the owen at 60 degrees Celsius.
The carrier gas is Helium and the flowrate is around 20ml/min.
The PID is set at the lowest attenuation and temperature set to 110 degrees C. The inlet and FID are both set to 110 degrees C.
The Headspace parameters are following:
Plateau 60
Loop 60
Transferline 80
Sample equil time 5min.
Loop size 250ul
Sample vial size 22ml
Now I've encountered few problems. First of all, I have to admit, that I don't exactly know what I'm doing, this methos is more like a trial and error setup, than a proper method creation. I'm more of a biochemist, with the opportunity and, should I say, responsibility of doing our chemical analyses as well.
My first problem is, that I get a mysterious peak from the PID at around 0,5min whatever I inject (even room air). I've cleaned the inlet and the ionization chamber. I've tried to clean the headspace as well, but I don't know if I did it properly. I get the peak even when skipping the HS and doing a manual injection.
My second problem is, that I'm doubting my method very much. I haven't been able to find much information on using a PID in sulphur determination.
The question that I'd like to present, is that is it possible for me to do sulphur analyses using this equipment? Should I change the column? Is there something critically wrong in my method?
Plateau 60
Loop 60
Transferline 80
Loop size 250ul
