Chrompack GC
Posted: Thu May 22, 2008 10:51 am
by alchemist
Hi there,
We have a chrompack GC CP-9001 running with a software called MOSAIC for retreiving data only.
Actually, we face alot of problems due to that version of software, it is a DOS version, the PC used is also old due to the compatibility of each other.
We are looking to change the PC, but the limitation is that the software will not work on a newr version of windows.
Could anybody assist us on that? we would appreicate all efforts
regards,
Alchemist
Chrompack 9001 under Windows
Posted: Thu May 22, 2008 2:00 pm
by jwmol
One option is to run the system with analog data acquisition only. CP9001 has an auto-ranging FID, you would be giving up that feature.
If you want to run under a recent Windows version, you would have to find 2nd hand interfacing modules and second hand software.
Both Varian and Scientific Software (now Agilent) used to have solutions for this old GC, but all these have been discontinued.
The communication used by this GC is very special. For that reason your Mosaic system has a special board inside the PC that is only supported by Mosaic. Later systems either used data acquisition (DAQ) only through the serial port, or they used a module called ComMod to translate the instrument control communication to another protocol. This other protocol required yet another card from varian inside the PC that is discontinued now.
JW
Applied Instruments
Re: Chrompack 9001 under Windows
Posted: Thu May 22, 2008 8:04 pm
by alchemist
JW
Applied Instruments
Thanks JW for your feedback.. at the same time i would have start searching about that systems.
If any reference you can refer me to it .. it would be greatful dear
regards,
Alchemist
Windows CDS for CP9001
Posted: Fri May 23, 2008 2:54 pm
by jwmol
I hostnestly think that it would be more efficient to buy a new GC than to find a 2nd hand CDS for this instrument. Even a second hand HP5890 would be easier to find than the items listed below if money is a concern.
If you must then you have these options:
1. Analog data acquistion, control settings from GC front panel, no instrument control from the PC
- Any modern CDS that can take analog signals. Note: you sacrifice the FID full dynamic range when in auto-range mode. Can only do fixed range on the FID.
2. Use a DAQ only version of Chrompack Maestro aka. Maestro 0. This only uses standard RS232 signals, no instrument control, use GC front panel for settings, full FID dynamic range when in auto-range mode is possible.
3. Use the full instrument control version of Chrompack Maestro II or CP-Maitre (same product, different name). For this you need 3 things in hardware which makes this an unattractive proposition:
a. ComMod interface box (protocol converter)
b. PCNet board, aka. ChromNet board. Be careful: this is an ISA board not supported in modern PCs
c. A PC that still has an ISA slot. Most likely a PC from a industrial PC vendor such as Advantech.
None of the above Chrompack / Varian parts are still on the pricelist. You would have to find everything on the 2nd hand market.
Good luck in your search.
JW
Applied Instruments
Posted: Sat May 24, 2008 7:43 am
by mcbart
You should also conside that old version of EZChrom support Chrompack 9001. Maybe you can find more info on Agilent website about this..
I know that 3-4 labmans that are using Chrompack 9001 in their laboratories and all are using Chrompack Maestro.
Varian guys maybe can provide you a copy of Chrompack Maestro: even if Chrompack 9001 is not yet available I know they are doing support and maintenance for Chrompack 9001
Re: Chrompack GC
Posted: Mon Dec 27, 2010 5:46 pm
by marlenl
hello,
Have you find any solutions?
Regard,
Re: Chrompack GC
Posted: Tue Nov 18, 2014 10:43 am
by SNasseri
Hi there,
regards,
Alchemist
Hi
I'am from iran and i have a solution for this problem. I have made that possible to run MOSAIC software under new pc and windows 7 os. Worked in centeral laboratory in Bandar Imam Petrochemical co.
for any question send me message.
Re: Chrompack GC
Posted: Tue Nov 25, 2014 11:33 pm
by Jonny Thinh
Dear friend,
I'm Thinh. I'm from Viet Nam and I got a big problem, I think.
I've got one Chrompack CP9001 but suddenly, my hardware of the computer was in risk. I can use it. Do you know where can I get the setup program to use it.The program was use is Chrompack Maestro version 2.4 .Giving me the recommendation to my Email: thinhvan11026789@gmail.com as soon as possible, please. Many thanks in advance
Re: Chrompack GC
Posted: Mon Jan 19, 2015 12:22 pm
by SNasseri
Hi Dear Friend
I have send an email please check and reply.
Re: Chrompack GC
Posted: Tue Dec 06, 2016 7:45 am
by srmeister
Hi there,
i have a CP9001 and unfortunately i dont have the ChromNET aka PCNet Card that is needed for Maitre.
Does anyone have the old software that can support this GC over a serial cable?
I think it is very old Maestro which works in Windows 3.11 or even DOS.
Any help would be much appreciated.
Bernd
Re: Chrompack GC
Posted: Mon Dec 12, 2016 6:10 pm
by marlenl
I have these cards if You are interesting.
Any version of maitre can work on RS232, also under windows7.
Kind regards,
Re: Chrompack GC
Posted: Fri Dec 16, 2016 11:16 am
by srmeister
Hello marlenl,
yes i would be interested in one card.
Are you sure that Maitre 2.5 on Windows 95 can work on RS-232? I cant find out how to make it work. Maybe a tip there?
Re: Chrompack GC
Posted: Fri Dec 16, 2016 6:37 pm
by marlenl
I sent email also.
Yes, I'm sure it is working, I have many. Maybe the problem is the cable, it is not a standard RS232 cable.
Kind regards,
