Nitrogen evaporators
Posted: Tue May 13, 2008 8:41 pm
I need to evaporate chlorform solutions of phospholipids using nitrogen. Currently we use a pierce Reacti-vap that is hooked up to a Gast air pump and we dry down our extractions using air. Problem is air will hydrolize or oxidize the lipids.
I've never had to use nitrogen to dry down specimens. How do you hook up nitrogen to an evaporator? How is the flow controlled? How do you turn off the flow? With an air pump all you do is turn off the pump.
We use N2 as a carrier gas for a GC/FID but I don't know how to hook it up to an evaporator.
TIA
Mike
TIA
Mike
