Plant Extraction Help
Posted: Thu Mar 29, 2018 5:52 pm
by sohaib1
Hello, I am trying to measure how much Ethylene Glycol is absorbed in plant. I am not sure how to extract he plant to analyze on GC-FID. Do i just mix the plant with water and then filter or is there something different. Can anybody point me into the right direction. Thank you for all your guy's help
Re: Plant Extraction Help
Posted: Thu Mar 29, 2018 11:18 pm
by Steve Reimer
Depending on the plant material I would start by grinding or mashing the plant material up in water. Then filter and see what happens. See if there is a problem with the matrix before you commit a procedure.
Posted: Tue Apr 03, 2018 3:42 pm
by sohaib1
oh ok i will try that thanks
