peak around .88 min
Posted: Fri May 09, 2008 5:05 am
I am running chloramphenicol using colume Hypersil gold,50x2.1,5u.
25% ACN(0.1% formic acid):water (0.1% formic acid) at flow rate of 200ul\min. I am gettting at huge peak at .88-.90 min. what could be that. I get the peak when I use Methanol instead of ACN. and also i am not getting stable base line too..method is so simple i am not able to figure out why.. I get my chp at 2.5 min with ACN and 3.9 min with MeOH..please advise
