chromeleon software problems
Posted: Fri May 09, 2008 12:16 am
by scio2
Hi there, wondering if anyone can help. I am currently running ion chromatography (dionex) using chromeleon software.
There appears to be a glitch in the software and the instrument stops after one injection in the sequence. Has anyone encountered this before.
Any thoughts?
Scio
Posted: Fri May 09, 2008 9:02 am
by Hfranz
Difficult without detailed information on the communication protocols between the instrument and the software. A setting or a minor communication problem might be causing this. Best will be to contact your local Dionex support and to provide them with a system status report (SSR). This report includes all required information and is created automatically (but can be customized) and will make a proper diagnose of the problem easy. SSR is included in CM 6.8, older versions such as CM 6.7, 6.6, and 6.5 can be upgraded. Please click here for details: http://www1.dionex.com/en-us/lp39254.html
Posted: Wed May 14, 2008 11:12 pm
by Arodrigues1975
I can help you if you send me backup of Audit trail file of that day and one backup of your sequence sample.
To large data please send trouhg www.yousendit.com
AR
