cGMP Question2
Posted: Wed May 07, 2008 4:58 pm
OK, another cGMP question. I work at R&D/pilot manufacturing facility, and we make OTC pharmaceutical consumer products. Am I correct that all raw materials and intermediates received here (each lot) for use in consumer products for consumer tests and OTC stability assays MUST be assayed to meet the same Acceptance Tests that are required at our full scale production facilities?
For example: if the API must meet our company's purity test, identity test, color test, and solubility test at manufacturing QC, must those same tests be re-run at R&D if that same lot is received there for use? I'd think YES, or how else would one really know what it is, and if it's OK (like if it was mis-labeled)? Comments please.
