detecting O2
Posted: Thu Mar 22, 2018 3:11 pm
by cb605672
I am having issues getting peaks . I am injecting an 8 ppm O2 in He. My set up is:
Pre-Column : Hayesep Q , Analysis Column : MS 13X, detector DID
I’ve heard in the past that if the column temperature is over 70 degrees , O2 is absorbed into the Hayesep Q . Is that right?
Thanks!
Re: detecting O2
Posted: Thu Mar 22, 2018 5:14 pm
by GasMan
If your sample is only the 8ppm of oxygen in helium, then why not only use the mol sieve column. This will at least tell you if the HayeSep Q column is the problem. At 8 ppm it could also be the Mol Sieve column.
Gasman
