EP column question
Posted: Fri Apr 25, 2008 4:08 pm
I've gotten my hands on an EP method that we need to use to test a raw material. The EP states that a end-capped polar-embedded octadecylsilyl amorphous organosilica polymer R (5 um) is to be used for the method.
I'm thinking that this means I could use an XTerra RP-18 as it is the only column I am aware of that is a hybrid (I take it that is what the EP means by organosilica polymer, but have no idea if it is type R) which also contains a polar embedded group.
Have I hit the jackpot, or do I need to go back to fishing; have I misunderstood something? I don't deal with the EP all that often....
