Chromeleon SST calculation help
Posted: Wed Mar 07, 2018 8:59 pm
Hello Everyone,
I was trying to calculate a standard agreement (or also called standard accuracy) as a SST parameter. The formula is ((peak area 1*standard weight 2)/(peak area 2*standard weight 1))*100.
I was able to have the software automatically obtain the weights amount within the amount table and the peak area of the first injection of standard from the chromatogram using this line in the SST table:
(peak.area*peakTab.amount(2))/(2.0788*peakTab.amount(1))*100
This calculation has the first injection as "sample condition".
However, as you can see, the peak area (2.0788) from the second standard injection cannot be automatized.
Do you have ANY idea on how to overcome this problem?
Thank you
Thank you
