Problem with Autotune on MSD 5973
Posted: Thu Apr 24, 2008 5:01 pm
Hi people!
I work a system GC6980/MSD5973 (with quad, EI, turbo pump), that was working good. But I changed the capillar column and then I conditioned that. After that I executed the Autotune, but that sopped with the message "can't achieve constant peak widths".
The vacuum is good.
There is PFTBA in vial.
The cal valve is open and I hear "click".
Check of leaks is OK (but the ion 69 abundance is very low).
The flow is 0.9, splitless.
The temperature of source is 230°C.
The temperature of quadrupole is 150.
Please help me.
The vacuum is good.
Please help me.
