Oily Sample Analysis by NP-LC
Posted: Wed Apr 23, 2008 9:02 pm
I have been attempting to create a Normal-Phase LC method for the analysis of degradation products of a small polar molecule of approximately 300 daltons. The analyte molecule is basic and is dissolved within an oily matrix. As such, the sample is being dissolved in chloroform before being injected. The analyte molecule and degradation products absorb at 290nm.
I have attempted the analysis with several different columns as well as normal phase solvent systems of differing relative polarity. Thus far, I have achieved the best results using a stable bond Cyano column. Elution is achieved by gradient from 95:5 to 50:50 hexane, and ethanol respectively. I am achieving good retention of my main band however it exhibits broad tailing. I am not able to detect major and minor degradation products that are present. I initially tried adding 0.1% TFA to the strong solvent in the hopes of sharpening the peaks but this had no effect. Thus far, I have assumed that the main band which displays extreme tailing is masking the degradants.
Is it possible that adding 0.1% TEA or isopropylamine might help? Anyone have any experience with the analysis of oily samples on a NP-LC system? Many thanks for any/all info.
