Detection of NOx using gas chromatography
Posted: Wed Apr 23, 2008 1:14 pm
Hello all,
I am looking to measure NO2 and NO using gas chromatography. We have used uv spectometer and an FT IR and have not been satisfied with the results. The first is just not that responsive time wise, and the second the water band interferes with the NO2. So we were thinking of using our GC. We looked into using an NCD however it seems like they are for very low concentrations of NOx.
We are trying to measure the NO2, NO, and any possible N2O4 in a gas that contains ~5000 PPM of NO2, the balance of the working fluid is non condensing humid air. I spoke with a sales rep from agilent and he seemed to think a TCD detector would work well in detecting such high concentrations of these substances. Now my question is what column type should be used to split NOx from air, water vapor, and each other (i.e. separate NO NO2 and N2O4).
