amines
Posted: Thu Mar 01, 2018 6:37 pm
by control
I´ve to test a method for MDEA, i need to know if the column i have can be used with water as solvent.
Column: WCOT FUSED SILICA 30MX0.25MM ID COATING CP-SIL 8CB DF=0.5 FOR AMINES. VARIAN CP7595
Do you know any method for MDEA by GC-FID?
Thanks.
Re: amines
Posted: Thu Mar 01, 2018 6:45 pm
by Consumer Products Guy
Maybe. But it "might" help if you specify what "MDEA" is. I know that "DEA" is Drug Enforcement Administration or could mean diethanolamine or diethylamine....
Re: amines
Posted: Thu Mar 01, 2018 7:43 pm
by control
its methyl diethanol amine
Re: amines
Posted: Fri Mar 02, 2018 9:09 am
by Andy F
This has appeared before. Have a look here.
viewtopic.php?t=24465
Re: amines
Posted: Fri Mar 02, 2018 11:16 am
by control
ohh thank you.
Could you tell me if the column i have can be inyected with water?
Re: amines
Posted: Fri Mar 02, 2018 1:02 pm
by control
Do you know any method of MDEA in air or emission?
Re: amines
Posted: Fri Mar 02, 2018 4:34 pm
by HPLC chemist
Re: amines
Posted: Fri Mar 02, 2018 4:39 pm
by HPLC chemist
Yes it is a regulated pollutant by the EPA (see attached). No I have not found the limit in air.
https://iaspub.epa.gov/sor_internet/reg ... ceId=47573#
Re: amines
Posted: Thu Mar 08, 2018 6:11 pm
by control
thank you..
Do you have any method of extraction for amines in air, water or soil and detection by GC-FID? i´m a little bit lost with this analyte...
