cysteine problem
Posted: Fri Apr 18, 2008 4:31 am
I purified a short peptide with 6 cysteine residues, one cysteine residue is between two alanine residues [A-C-A]. When it came to read this cysteine residue on the amino acid sequence machine, both cysteine and alanine were increased (alanine was higher). Is that a kind of misreading or......?
Also another cysteine residue at the end of this peptide wasn't detected, any clue......?!
Also, there are 2 tyrosine residues in this peptide, the concentration of one tyr residue was too little, does anybody know why?
I tested the specificity, Mr value, and gene ecoding for this peptide and everything was ok......
Thank you for your attention
