5890/5972 Chemstation B
Posted: Fri Feb 23, 2018 11:50 pm
Hello All!
Does anyone know where I can get a copy of Chemstation B, verson TBD, compatibility tables for old firmware? I have a 5890/5972 with an ALS that has an outbound controller. Right now I have Chemstation C which can only control the MSD and acquire data. The GC and ALS I’ve set to run in standalone mode so the GC and ALS methods are programmed on the GC Keypad and ALS tower. It’s a bit of a pain to to have to remember to set everything up correctly, but the unit runs beautifully - still a work horse!! My favorite instrument because it’s the underdog.
I think Chemstation B will comparable with the the entire system so we would no longer need to run in standalone... any advice would be great, thank you so much!
