Polarity switch in Sciex Qtrap 5500
Posted: Fri Feb 23, 2018 5:05 pm
by mateusarsouza
Hi all,
I am using a HPLC Agilent 1200 coupled to a mass spectrometer Sciex Qtrap 5500 and an Analyst software. I am working with many analytes and I wish to use polarity switch experiment (two experiments at same time, a positive and a negative). I tried and obtained a chromatogram with many peaks, as expected. So, I tried to do the command "Extrac ion" in the chromatogram and get the message that I can do this only when I use only one experiment (positive or negative). Anyone knows how can identify the peaks or obtain the chromatograms for each mass transition when I am performing polarity switch experiment?
Thank you!
Re: Polarity switch in Sciex Qtrap 5500
Posted: Fri Mar 02, 2018 9:11 pm
by haole
If you're using analyst, at the bottom along the X axis there are two arrows pointing down and away like ^. If you double-click on that it'll expand out to display the (+) and (-) TIC. From there you can find your XIC.
