ABI Cliquid software
Posted: Tue Apr 15, 2008 5:55 pm
by yangz00g
Any has comments on this software? Thanks
Cliquid
Posted: Wed Apr 23, 2008 9:44 am
by Killerwhale
Hi there,
we have been planning to install this software into our laboratory but we ran into some issues and have decided against it. The reason is that running assays though Cliquid will require you to perform separate Screening and Quantitation runs. It is not possible to run the two together through Cliquid.
Also you need Windows 2003 I think as they have not tried to run it on anything higher yet.
Hope this helps... :)
Cliquid Screen and Quant
Posted: Sun Jun 08, 2008 1:15 pm
by Ken
Hi there.
I have been using this software and I think this software is good and powerful and its very easy to use.
Despite what Killerhwale said, I dont have any problem with this software ; basically I have Cliquid Drug Screen and Quant and also the Cliquid for pesticide screening.
The software is able to perform both screening and quantitation with no problem at all in a single injection; depending on how you want the software to report your analyses.
So, I am not sure why Killerwhale said you need to do both separate injections for screening and quantitation.
I am an end user; what I know is that the software has make my life so much easier and simpler to work ; especially to the technicians who just want to use the software without the hassle of knowing method development.
Of course, I will have to develope methods for new analyses - cant escape from that !!! :) - technicians have much simpler life but at least, I have Cliquid to help me....
Hope this helps !! Cheers...
