"MS communication : Disabled"
Posted: Thu Feb 22, 2018 5:08 pm
by JeremieUlaval
Hi, after a shutdown of the MS (power cut) I see on the statut of the GC MS agilent 7890B "MS communication : Disabled", I want to know if i can reconnect the MS communication. But I don't remember if before the power cut the statut was "MS communication : connected", I think yes. Is it a problem to continue with this message in the statut ?
Thank you,
Jérémie.
Re: "MS communication : Disabled"
Posted: Fri Feb 23, 2018 11:00 pm
by James_Ball
Thank you,
Jérémie.
Try loading the control software and see if the message goes away. My 7000 triple quad displays that message all the time but it still talks to the software.
Posted: Sat Feb 24, 2018 8:22 pm
by aldehyde
Hey this is benign and you're better off leaving it disconnected.
You can connect the GC and MS via LVDS cable and then configure communication from the front panel of the GC using the aux detector or ms detector button on the GC. It doesn't add many features, leaving it off is fine.
