column problems
Posted: Sat Apr 12, 2008 11:04 am
Dear all,
I have been facing some problem with my current assay.
My RT of my peaks are shifting by at least 0.4 mins after only 40 injections. The RT is slowly shifting further after every few injections.
I have not faced this problem when i was doing the same assay previously.
During this assay, column pressure also starts increasing slowly after every few injections. In previous assay, pressure still remains the same after about 70 plus injections (I run at least 70 plus injections for each batch/day). Increase of pressure during each run might b just around 1-2 bar but it never affects the RT. I have had certain batches where pressure does increase significantly but RT remains constant because the pressure increase was caused by a blocked frit or guard column.
I always flush my column after bout 150 injections. I initially thought that the slight increase of pressure and the shifting of RT might be caused by a faulty frit or guard column but both are new.
I have suspected that maybe my column (up to now, the column has been injected at least bout 1000 injections) is dying but not too sure about it. Peak shapes are all still good though.
It would be nice to have other views or opinions regarding this situation. Thanks!
