Chromatograms Missing in Empower2
Posted: Wed Feb 14, 2018 6:24 pm
Hi all,
I'm running into an issue with the Empower2 review feature. When running samples I can see results with review and it will process the information just fine.
The next day however, my processed results remain, but all the data when I choose to review is gone. No data shows up, not even the "pressure" graph that would normally show up before the method set is applied. This has affected all the data in the project folder.
Thinking its something to do with the pressure processing method so I'll play around with that. Are there any other possibilities that I'm missing to get this data back?
