UPLC vs Aglent 1200 rapid resolution
Posted: Thu Apr 10, 2008 12:09 pm
by mondy
Please give me your experiances with this systems,especially in aspect transferring method from one to another.How much are they compatible .
Thanks in advance
Posted: Wed Apr 16, 2008 3:45 pm
by mbicking
These are two different systems from different manufacturers, with different designs and software.
You should expect differences whenever you switch methods to a different instrument. If you have a simple isocratic method, the transfer may be easy. If you have a gradient method, some adjustment of operating conditions will probably be required.
Posted: Thu Apr 17, 2008 11:02 am
by mondy
Thank you
