Rough Pump Choices
Posted: Fri Feb 09, 2018 3:40 pm
by cjm
Hi all,
I'm currently running 2 5975s, one coupled with a pfeiffer duo3 and the other with a duo2.5. The 2.5 is leaking like crazy and I'm looking for an alternative with longer lifetime. Our duo3 is going great and has been for maybe 4 years. If you had to swap out a 2.5 for something more reliable, what would you choose? Older rotary vane pumps? Dry scroll? I'm weighing options and would love to hear what others would do.
Re: Rough Pump Choices
Posted: Fri Feb 09, 2018 8:40 pm
by James_Ball
I have Edwards E2M2s on all of my Agilent 5973/5975s. These pumps are all nearly 20 years old and have never been refurbed and all work great. I do plug them directly into an outlet instead of the back of the instrument so I have to unplug them when I vent, but otherwise the best thing I have done for them.
Most of the pumps were salvaged when we upgraded the 5970/71/72 units to the newer models, even a couple were from the 5995s we had. They really help if you run more than 1ml/min column flow also.
My Agilent 7000QQQ has an Edwards RV5 and on it when running normal scan in single quad mode I normally run with pressures at 7x10^-7torr, so if any of these fail I may consider using one of those if I can make it work.
Posted: Fri Feb 09, 2018 10:18 pm
by LALman
I like them plugged into an outlet also. Because, when I vent, I can leave the system under low vacuum until I am actually ready to open it up and service the source.
Posted: Tue Mar 13, 2018 5:00 pm
by twranger
We have been replacing our Edwards E2M1.5s with RV3s, they are quieter and perform better. The Pfeiffers have performed poorly, leaking soon after installation.
Posted: Wed Mar 14, 2018 4:42 pm
by Gizmo
We were going through about two pfiefer pumps a year when under contract with agilent on our 5975. Finally switched to an edwards E2M1.5 a few years ago and once again have had no pump issues. I say once again because before the string of horrible leaky pfiefers I had an edwards pump on a 5971 that came with that instrument back in 1993 and never needed repair and is probably still running somewhere.
