Selection between RP, HILIC or Ion chromatogrphy--Flash LC
Posted: Fri Apr 04, 2008 12:30 am
I am using C18 RP silica in Flash LC for separatin of tetracycline and its oxidation products at prep scale (~200 mg) but some of the products react with the RP silica and stay their permanently as visible by the brown color...I feel the acidic compounds are responsible for that. Also TC is highly tailing compound. One more problem is that I start gradient with water(amm. formate):ACN 10:90 at which sample is not very soluble and increasing ACN to dissolve the sample causes some compound to elute at solvent front.
RP is suitable for this or should I change to HILIC or Ion chromatography?Are the stationary phase of HILIC or Ion C available in market for flash LC?
Or simple normal phase silica is sufficient?
