Waters 2695 pressure drop...
Posted: Sat Mar 29, 2008 11:30 am
I have a Waters 2695 LC system that has a very strange problem..
When pumping phase (I am using water but the analysts are using a buffer) we are seeing a drop in the pressure which causes a peak in the baseline.
The strange thing is the pressure drop is not random it happens ~ every 8 minutes. I have changed the check valves which has sorted another pressure problem but am still getting this pressure drop.
Anyone got any ideas?
