n-heptane as an exchange solvent for hexane
Posted: Mon Jan 29, 2018 11:49 pm
Has anyone tried using n-heptane as a final solvent when blowing down hexane to lower volume. Also, who prefers n-heptane for GC-FID DRO analysis and why?
Chromatography Forum is a public discussion group where you can post questions, news, or messages of interest to chromatographers everywhere, but you must be registered to participate (registration is FREE). If you are a registered user, please log in.
https://www.chromforum.org/
Yes, I am aware. I was thinking that if one dried down at modest temperature 40-50C. Then you could add 1-2 mL of n-heptane to larger volume of (n-hexane and DRO) mixture for example. Blowing that down would effectively transfer the DRO into 1-2 mL of n-heptane. That in turn can be dried and transfered to capped vial for analysis.Perhaps you are not aware of the fact that these two different solvents have very different vapor pressures and boiling points? n-Hexane's bp ~ 69C and n-Heptane is close to water at 98C. Using heptane to dry something down would be a step in the wrong direction.
Link to "HPLC Solvent Properties Table (e.g. Polarity, Density, Boiling Point...)"; https://hplctips.blogspot.com/2011/11/h ... table.html
It would, but it was not clear whether you wanted to evaporate to dryness, or to a fixed volume.I thought perhaps I could avoid accidentally having my whole sample evaporate to dryness while I was attending to other things in the lab. I thought maybe evaporation would slow greatly as the volume approached that 1mL of solvent that had twice the B.P..
