how to create a custom field for calculations?
Posted: Thu Jan 25, 2018 8:06 am
by LCBigginer
how to create a custom field for any calculations?
I can not find an option in Empower 3RF4 to create a custom field to make formulas or calculate anything. calculating the amount is already set up, but i would like to try and create a formula for calculating impurities but don't know how..
Re: how to create a custom field for calculations?
Posted: Thu Jan 25, 2018 10:45 am
by ydna1977
Hi
Open configuration manager and project properties
Custom fields are here
Follow wizard to create custom field
Have a look online for example custom fields
Testing of these fields will require some thought
Posted: Mon Jan 29, 2018 10:14 am
by LCBigginer
thak you so much for taking the time to answer my question. I followed your instructions but it seems that I don't have authorizations to create new custom fields and this is the reason i had difficulties with the issue.
i will try to sort it with out IT dept. and hopefully come to some solutions!
Thank you :)
Posted: Mon Jan 29, 2018 3:58 pm
by EmpowersBane
You have to have "Superuser" or "Admin" access to create/edit and delete custom fields.
