micro bondapack C18 column
Posted: Wed Mar 26, 2008 10:23 am
I would like to know what is micro bondapack ?
THANKS,
TK
THANKS,
TK
Chromatography Forum is a public discussion group where you can post questions, news, or messages of interest to chromatographers everywhere, but you must be registered to participate (registration is FREE). If you are a registered user, please log in.
https://www.chromforum.org/
Look at p108-109 of your Phenomenex 08/09 catalogue. There you will find that just one Pharmaceutical regulator ( USP ) uses a diverse range of columns and particles sizes, eg L1 is C18 from 1.5 - 10 um or a monolithic rod.The fact that microBondaPak is still used says a lot about the inherent conservative nature of the regulated Pharmaceutical industry.
When develpoing methods I would never look at it as it is a 10u irregular packing and the 30cm one is very difficult to get into modern column heaters.
I have never needed a column longer than 15cm when developing methods.
Waters take advantage of their position and charge very high prices eg £504 = $1000 (UK) for a 30cm column.
Phenomenex make a column which can be substituted in most cases called Bondclone.
PS I have no links with Phenomenex
