hi everybody,
I'm trying to create a CSV file with a sequence run and then importing it into MassLynx. Following the directions of the help menu I came up with:
Index,ID,FILE_NAME,FILE_TEXT,MS_FILE,INLET_FILE,SAMPLE_LOCATION,INJ_VOL,PROCESS_PARAMS,PROCESS,MASS_A,USER
1,sample#1,sample1,sample description,MSmetod,LCmethod,1:1,2,processMethod.olp,OpenLynx,100,Fname Lname
When I tried to import it I get the error message: "error in the 'from' clause"
I tried some variations of the CSV file, like sorround the text field with ' (ex: 'sample description'), eliminate the first line or the index...
I always get the same error.
Does anyone have a working sample of a CSV sequence file I can take a look at?
I appreciate all the help you can give me.
thanks;
Sergio
